I just finished "winterizing" my 3.0LX. I live in Sudbury,ON (-40deg).<br />-I changed engine oil/filter.<br />-I changed the outdrive oil(I only put 12 hours on it last summer, was this nessessary?) The lube in the reservoir looked like the stuff in the bottle.<br />-Fogged the engine, then poured some in the cylinders, removed the coil wire, cranked the engine a couple of times.<br />-Removed hoses, opened petcocks, poured in anti-freeze (AF) till it came out of petcocks, left all drainage open, including hull.<br />-Removed battery, silicone spray-lubed the outside of the engine.<br />Question 1) Does pouring in AF till it comes out fill all voids re:freezing?<br />Question 2) Should you change the oil in the trim reservoir?
