Michael Bel
- Oct 24, 2017
- 3
Filled the block and maniflolds this fall by first draining the water pump, block, and manifolds of all water, and then taking off the manifold bypass hoses and water circ pump hose, and then filling with RV fluid. My question is whether of not the raw water intake hose coming from the impeller is self draining, or if that hose should be removed at the thermostat and then backfilled with rv fluid. My understanding is that there is a power steering cooler in this line that may need protection. The manual does not mention this hose in the instructions for winter storage. Also, if you do not remove the line from the thermostat, is water retained at the thermostat that may cause a breakage or leak at freezing temps?
