winterizeing
laker_jim
hi what i would like to no is -i have a 3.0 OMC Cobra i just drain the block and the water cool exhaust manifold now i want to put the antifreeze in when i was flushing the engine i did not see any water coming out of the block ( drain plugs are out for now )do i have to run the engine with the ( i no the drain plugs back in ) in to get the water back in the block & exhaust manifold <br />thanks Jim
tommays
Re: winterizeing
did water drain when you removed the plugs ?? if not they are blocked with something you need to poke around with a wire and drain the parts<br /><br />around here 50% of the people drain all the water and store the motor empty so as not to have to deal with the envio problems of antifreeze its all toxic even the no-tox just read the back<br /><br />the other 50% use the anitfreeze method <br /><br />i am in the drain and compleatly and it cant freeze 50%<br /><br />tommays
