I guess I'm just venting here, but I'm also curious what could have gone wrong.
I've been winterizing the boat since I've owned it (8 years), this is the first time with a problem.
I drain the block, manifolds, poke around in the manifold hole to make sure it's clear, disconnect the water hoses at the water pump & thermostat housing, then reconnect everything and pour the pink RV antifreeze in from the top water hose until she's full. Maybe this Michigan winter got too cold for the RV antifreeze, or maybe I had some trapped water....but either way my port side manifold has a nice big crack on top now. Pink antifreeze started shooting out the crack as soon as the engine was running.
It got too late last night and I didn't check out the rest of the engine, but I know I have at least a manifold to replace.
The boat is a '94 - been in Michigan fresh water all it's life. Do you think I might as well bite the bullet and replace both starboard and port side manifolds? Do the risers have a limited lifespan and need replacing as well since I'm in there already?
No boating for me this weekend
