winterize
USMC62
ok this is my problem...50hp marnier Im at the lake of the ozarks....the water is to low for me to take the boat out now...it's in a covered dock...some water under the pontoon...and motor at this time...the motor is in the tilt postion (up).covered prop with plastic....how in the world am I going to get all the water out of the engine? now?....we have not had a freeze yet..the water will go lower and the lower unit might be able to be put down...if the freeze does not come first...in trouble...help....ran fuel out of the eng.....that's done..help
carholme
Re: winterize
If the water is that low, why not get into it with a pair of hip waders and remove the lower unit. The remainder of the engine wrapped in plastic should be ok until the spring. Shove some grease up into the crank splines (where the driveshaft fits) to prevent any corrosion and just remember to adequately clean the grease out when spring comes.
Gerry
USMC62
Re: winterize
ok thank you never thought of that.....how hard is taking it off?.. 50 hp mariner 1990.....and how about the line up to put it back on??? thanks for your help..
Mike
carholme
Re: winterize
Mike;
No problem to take it off as you just undo the mounting nuts and allow it to drop. Before completely removing the main mounting nuts which you can see on the side, remove the trim tab and also get the nut under it.
When it drops, just do not remove the cam which you will see on the splines of the LU shift rod. If you do not remove it, you won't have a problem going through aligning it when the time comes.
If you post your engine s/n, I will get the parts listing for you, so you can see the items we are talking about.
Gerry
USMC62
Re: winterize
Mike;
Gerry
What I do have is this number OC252084 on the title.....50hp 1990 mariner.....sir I thank you for your help....
carholme
Re: winterize
That s/n comes up as:
MARINER - ( 50 H.P. (1990 ))
Serial No: 0C252084 Model No: 7050412SD
Parts Listing for model 7050412SD:
http://www.crowleymarine.com/mercury-outboard/336.cfm
If you look at item 50 (Cam) under GEAR HOUSING (DRIVE SHAFT), that is the one to look for when you drop the LU.
Item 74 under GEAR HOUSING (PROPELLER SHAFT), is the trim tab and once removed you will see tha hardware underneath, to be undone.
If you get this in time, here is a link to the Clymer Service Manual, which will help you get the LU off and back on later:
http://web.ebscohost.com/serrc/pdf?...ba1c-2d48effdfab7@sessionmgr104&vid=4&hid=112
See page 147 for the beginning of the LU removal.
Download this soonest to your computer as the link is short lived.
Gerry
USMC62
Re: winterize
Gerry, you are a life saver...thank you very much...I was looking for a manual and they wanted money first....I now understand how to do this...I will cover the opening under the housing with something to keep elements from getting into it....I will take the lu home and change the impeler while I have it here...wow I can do this!!....again thank you for taking the time to help this old Marine...
Mike
carholme
Re: winterize
Mike;
Good luck with it, you should have no problem but if you do, somebody will be here to help you.
Gerry
