Winterize Sea-rayder F16
ProbeGT
Appart from removing the oil in the gearcase and stator in case there's water and it freeze, and also pouring some oil in the cylinders and stabilizer in the fuel, is there anything else I need to do?
I'll also remove the battery to keep it in a warm place on a low amp charger.
does the engine drains itself since it's jet propeled?
H20Rat
Re: Winterize Sea-rayder F16
yep, self draining. fog it, change the stator and pump oil, and you should be good to go.
