wintering or not
jarob
87 90hp Johnson. Is it preferable to go through the wintering down procedure on the motor when it is not going to be used for several months or put the muffs on every couple of weeks and give it a run for 15 minutes or so?....Thanks
BoatBuoy
Re: wintering or not
Probably better to winterize. Where you live, there may be times when the hose is frozen, or you just don't feel like getting out to give it a run. I know I would have those times.
JRJ
I'd run it once in awhile if freezing isn't an issue.
jarob
Freezing is not a problem and I enjoy giving it run so thats what I will do ...Thanks
