danielclubs
- Jun 5, 2006
- 9
This is my first spring with my boat and I'm just trying to make sure I have everything taken care of. I have an '86 Starcraft with a 75 hp Mercury on it. Tonight, I put muffs on it, turned on the water, and started it up. It started right away and sounded good. However, I didn't notice water coming from the tube just below the head on the back of the motor. Water was coming out from the muffs as if the impeller wasn't taking it. When I noticed this (about 10 seconds) I killed the motor so it doesn't burn up. Does it take a little time for the water pressure to build? I put the muffs on the set of holes in front of the the propeller. Thanks!
