Windlass
boatingfun0238
I have a 40' Express Cruiser. It has two rocker switches on the dash along with a breaker below. The 1st rocker is a lock out to prevent accidental anchor release. The second is the up/down switch. I have released the lock switch, reset the breaker and still get nothing when the switch is engaged up or down. It worked at the end of the season. Any suggestions?
alldodge
:welcome: to iboats
Need to brake out the volt meter and seeing what voltages you have. I have the same setup so start with the switches and let us know what you find. Could be something as simple as a bad switch
