Re: Windlass Class 31 Water in Anchor Locker
You need a drain hole in your rope locker. All windlasses have the hole where the rode passes through pretty much wide open, that's why you need a drain. Hell, you need a drain even without a windlass!
At the lowest point aft on the starboard side, drill a 3/8" through the hull. On the outside of the hull, cover the hole with a 1" clamshell, oriented so the clamshell is facing downward and aft at about 45 degrees...good to go!
