sirtweek
- Jun 30, 2008
- 15
Howdy
I have a 79 Wellcraft tri hull with a 40hp Nissan OB.
My top speed is 20-21mph. It planes out between 11-15mph.
I have ordered one of the hydrofoils for my motor to see if that helps plane quicker.
The gas tank is in the back of the boat so the rear end always seems to sit down in the water, worse when people are sitting in the back. I also notice that when I am out by myself it leans to starboard as it is a starboard console.
Wanted some input on adding a set of lenco electric trim tabs.
A couple of the things I read and wanted to find out about is that if with boats that are heavy in the rear end you are better off getting the bigger tabs as it will help plane faster. I plan on repowering to a 70 or 90 hp in a few seasons so would I have to upgrade the trim tabs when doing so?
thanks for reading
thanks for reading
