will standard shaft replace xtra long shaft motor
woody1234
i have a 1995 vip deckliner with a force 120 hp xtra long shaft.motor is trash. all i can find is standard shaft 88 - 90 force motors.i would like to know if i buy an 88 force 125 standard shaft with a cmc jack plate and can i drop the mounting 4 inches if i do it will still be an inch to high.will this affect the power and handling? from the top of the transom to the bottom of boat is 27 inches.
RRitt
Re: will xtra long shaft replace standard shaft motor
you'll be more likely to cavitate.
jerryjerry05
The difference is 5 inches between the long and standard.
Sounds like it's not quite right.
Look around there are lots of those motors around.J
ljc1957
When I rebuilt my transom, I raised it 2". This caused my outboard to cavitate.
