I have a 16 foot speedboat with a 60 hp Mariner four stroke engine from 2001. The hole shot is good with two or three people on board. The problem is, however, that when pulling a water-skier out of the water the boat seems to lack a bit of power and doesnt plane of as easily. The skier will get up, but I just wish it happened a little quicker. The propeller is a Black Max alloy with 10 2/3 or 10 1/2 inch diameter and 13 inch pitch, which gives at top speed of 32-33 knots at WOT at 5950 rpm (recommended 5500-6000 rpm).<br /><br />I have read about the performance vent system (PVS) and I have thought about drilling holes in the propeller to give a better acceleration while pulling a skier. I dont know if it is a good idea because some people say that the PVS only has effect on larger engines. What is your experience/opinion on this? Should I drill the holes or should I try with at propeller with more than three blades, designed to give a better hole shot?<br /><br />Thank you
