Will low lower gearcase lube cause........
Phantom17
Will low lower gearcase lube cause a slippage, like in a car when the transmission fluid is low. 1981 OMC GM inline, 400 O/d. At low rpm it feels like the O/D is slipping.
blackz3
Re: Will low lower gearcase lube cause........
could be the prop slipping maybe??
Phantom17
I thought that too, how do you check for that?
Phantom17
and, it only happens at low rpm, unless it's normal not to feel it at higher ones.
tommays
if it is an electric shift, yes<br /><br />i dont no the last year before they changed <br /><br />tommays
Phantom17
Not electric shift. I have a second prop to try once I can get it to the water. Any of you guys have a suggestion to test for prop slippage out of the water? I have no tilt motor so I have to drop the boat in, test the fluid change "solution" (needed it anyway), and then try switching props. Thought maybe I could test it on land. Thanks
QC
IMHO the prop slipping would get worse with increasing RPM.
Phantom17
Thats what I have read, but I can't seem to get any answer. Any other ideas to the cause?
