Will JB Weld work on bypass cover and pressure barb?
ba_50
Well the drill and tap job left a little slop in the barb fitting for a fuel conversion. Will JB stand the heat? Thanks.
Isaacm1986
Re: Will JB Weld work on bypass cover and pressure barb?
yes it will, I am a huge JB weld user, I have used it to repair engine blocks before without a problem! i will stand the heat no problem, just use the normal stuff, it is a lot stronger than the 5min set stuff.
aclmvh
I used JB Weld to repair some pitting on my engine block cylinder deck with great results.
