Re: will cap/mag removal affect timing?
Hi Mred,<br /> As long as you're not messing around up top with the timing belt, you shouldn't mess up the timing of the magneto. It has a driveshaft with a flat on one side so it will only go back on one way. <br /> When removing the magneto, you may want to scribe some marks on the various stamped steel pieces that actuate the carburetors from the magneto tower. <br /> To remove the magneto, remove those steel pieces, then remove the four bolts (should be 7/16" head bolts), then start with the wiggling, twisting, and occasional cursing to get the magneto out. You may have to try different positions of the shift linkage to get the room you need. Once free of the tower, remove the ground strap from one of the lower cover screws. Also, remove the kill switch wire from the post on the side of the mag, and remove the spark plug wire anchors from the side of the exhaust cover.<br /> Once out of the motor and on your bench, remove the rotor cap (plug wires coming out of it, held on by two screws). Be careful prying, as it is a bakelite type plastic and is brittle. Next, remove the rotor - again taking care with any prying. Next, remove the magneto cover (four screws). Clean and gap the points (.008"). If you suspect the condenser, a small engine shop should be able to test it for you.<br /> To bench test the mag, ground the mag housing against a bench vice, then hold the copper tang from the vice about 1/2". Spin the splined rotor clockwise (looking down). You should get a good blue spark to jump that gap. Second test: reassemble the mag, still on the bench. Place the plugs in the vice, ground the mag body against the vice and spin again. All four plugs should fire, one at a time.<br /> You really should get that '65 and prior manual from Grubb's (
www.oldmercs.com) which has a really good section on setting up the old 4-cylinder mags.<br /> Good luck!<br />- Scott
