Will a 75hp engine block fit on my 90hp clamshell engine?
pedroofn19
My old 90hp outboard has really bad compression, and misfires all the time on one cylinder. The mechanic says it need a rebore, but there is no way I can afford that. I can get a 75hp engine block, with the pistons and crankshaft still in it for a reasonable price. WILL THE 75HP BLOCK FIT ON MY OUTBOARD????
Thanks for reading.
Faztbullet
It will fit but you will need to change lower unit to the 2:3:1 ratio for it to work correctly...
pedroofn19
Faztbullet thank you for your reply, is that gear ratio 2.3:1 ?
I have the Mariner service manual for my engine and it says "gear ratio 2.3:1 for 3 cylinder engines", and 2.07:1 for 4 cylinder engines.
My engine is a 3 cylinder so I guess the gear ratio should be 2.3:1, would you agree?
Please excuse my ignorance on this subject, and let me know if I am wrong.
Thank you.
pedroofn19
Sorry I forgot to say in my original post it is a 3 cylinder, 2 stroke, Mariner from the early 90s, the one with the clamshell engine cover.
flyingscott
Hello I could be wrong here but if its the 75 hp that shares the block with the 90 hp. You may be able to convert the 75 to a 90 do a parts search and should interchange.
Faztbullet
When you posted old I figured you had a Inline 6 90hp. Yes the 75 will bolt up just make sure it about the same year . The earlier models was 71.1 ci and the 1994 and up are 84.6 ci. The worst you could get is a 80hp motor
pedroofn19
I should have said all that in my first post. I have asked a lot of outboard mechanics and 99% of them said yes I will fit. Im sure both blocks were made within a year of each other. Thanks for the advice guys, it was very helpful.
DavidMoore
If my memory serves be well the only difference betwen the 75 and 90 HP versions of that engine is the 90 has bigger carbs.
Hope his helps.
pedroofn19
That is what I thought DavidMoore thank you. I have the carbs from the 90, so it all looks good. Thank god for that as I cant afford another engine. But swapping engine blocks will be a real challenge for me, but Im sure I will get it right in the end.
Thanks for all the helpful info guys.
