Re: Will a 225/75/15 work for a spare in place of a 205/75/15?
The 225 is going to be 30mm larger in Diameter than the 205.
So the axle will ride 15mm (0.6") higher on that side.
You probably won't notice the difference nearly as much as riding on the flat tire.
Does a "Great Deal" mean "Nearly free" or "I can save $20 by buying the wrong/out of date Tire?"
Check the date code on the sidewall before you put up the cash.
If it is too good to be true......
