Will a 1974 weedless lower unit fit into a 1973 evinrude 4
pgp405
Need a new lower unit for my 73 4hp found a 1974 lower unit online. Will it fit my motor. The lower unit that was on the 4 was a weedless. Any help would be great thanks
hardwater fisherman
If they are both weedless than yes but not sure if the standard guts are the same as the weedless.
TN-25
You can use a weedless "foot" on a 1964 - 1972 high thrust 90 degree l.u. For 1973 the high thrust lower unit & midsection changed and carried through for a bunch of years (into the mid-80s). No longer could you just swap the foot over, but you could use the complete l.u & midsection from the donor.
Attached are picture of the 1972 models and the 1973 models.
1972:
1973 with new midsection on the high thrust model (Yachtwin):
Many thanks for Liquidnirvana posting some of his vintage brochures in Webshots years ago.
pgp405
Thank you for the help. I believe this will work out on mine. Mine is a 73 lightwin and the 74 l.u looks exactly like the one I took off.
