bowhuntrrl
- Mar 26, 2003
- 320
I checked the part numbers out at Browns Point and they seem to be different although a lot of the individual parts are the same. They also look identical. The only different part numbers are the housings and pistons, the rest looks the same. Does anyone know if they are interchangeable ??? I've found a parts motor, but it's out of state and not really sure what I can use off of it. Thanks.
The problem I have is that the starboard trim cylinder is leaking. It looks like someone grabbed the piston rod with vice grips at some point previous to my purchase last fall and the chip and marks in the chrome ate up the seal. The piston is obsolete, so I have to scavenge up some parts.
