wiggleable honda propeller
socalboataddict
hi folks<br /><br />i have a 2000 honda 9.9 hp motor and just noticed that the propeller can be wiggled just a bit as compare to the mercury 9.9 hp that i also have. the merc. prop is quite tight. <br /><br />is that normal for honda prop to have a slight play in the prop. <br /><br />thanks
Navigator
Re: wiggleable honda propeller
addict...<br />The Prop should be tight on the shaft without any play. The shaft however, will have some degree of play. This is normal.<br /><br />Nav :cool:
