wierd problem
92rslt1
Does anyone know if the force 120 L drive has a shear pin in it? It wont transfer power to the lower unit. The motor will run as normal and rev up. I found that the lower unit is 100% functional. However the drive shaft to the lower unit never spins. The water pump doesnt pump or anything.
If I look under the motor inside the boat and spin the motor over the shaft I see coming out of the bottom of the motor isnt spinning.
If I place it in gear and spin the prop the shaft under the motor will spin.
jerryjerry05
Re: wierd problem
Could be :drive shaft broken,prop hub spun,shift linkage .J
92rslt1
Re: wierd problem
this might help, you are looking at the bottom of the power head inside the boat.
jerryjerry05
Re: wierd problem
Sounds more and more like a broken shaft or the engine coupler is bad.J
