why would i get exhaust smoke out of right side only?
wpowell323
i have a 2007 crownline with a 350 mag MPI. It has 90 hours on it and seems to run perfect. It has corsa silent choice exhaust with cutouts on the side. Here lately I have been seeing exhaust smoke at idle, but only on the right side. There is for sure exhaust coming out of both sides, but like i said i see smoke frome the right side. It does not seem to be oil smoke and doesn't really have a smell that i can tell. It also dissapates very quickly. If it were both side I wouldn't worry, but since it is only one side I am wondering what might be causing it?
smokeonthewater
Re: why would i get exhaust smoke out of right side only?
blue = oil
black = gas (rich)
white = water
wpowell323
it is white...i thought steam, but nothing on that side seems hot to the touch, at least not anymore than normal...
jerryjerry05
It's steam.Nothing to worry about.
The cooling water will go the easiest way out.If the impeller is old or weak it might not be pumping as much water.J
gjm700
Don't worry. Its only steam.
