BigBassin78
- Aug 13, 2011
- 64
I cant tell if I have an issue with my motor, or if it is with the setup of my boat. I have a 16ft Hurst fiberglass bass boat 78 model with a 78 Evinrude 115. It is a relatively light boat, I would guess that is is about 750-900 pounds dry, with me and my buddy, fishing gear, and fuel about 1100. When I am out by myself the boat pops up on plane without hesitation it will run about 50-52 at 5800 RPM. Add my buddy and a little more fuel and it wont plane or reach more than 3000RPM without him getting closer to the bow, it will run 47-48 at 5800 RPM. Here's the kicker, sometimes it will get up on plane without him moving towards the bow!! The motor seems strong and runs like a top, but why wont it plane sometimes with just a little more weight.
I just feel like 115 should be plenty to push my little 16 footer out of the water,
info: prop does not have stamp, so I do not know the prop specs. The motors standard prop size is 19" pitch by 13" diameter, Im sure the prop that is on there now is not anything higher than 19" pitch.
