muskie hunter
- Jul 29, 2007
- 158
I know what everyone is going to say about not expecting high mpg while towing but this is different.
I have a 1996 wellcraft excel 26 se cruiser w/an aluminum trailer. total weight loaded for a trip is about 9500 lbs. I pull the boat w/ a 1997 GMC yukon 2dr with the vortex 5.7 3.73 gears without the boat I get 17, with the boat behind it I get 8.
Now I borrowed my buddies 2001 ford f-350 7 liter turbo diesel 4.10 gears for a run from ohio to lake michigan last week. He stated the truck unloaded gets about 18 mpg,and that I should expect about 14-15 while towing the boat.
I could not believe it when after 1000 miles the truck averaged 8.2. Not only was I in shock.. the truck owner was shocked also. He said he never got that bad of mileage while towing anything. Granted it pulled much better than the yukon,but I would have expected much better mileage from it also. The truck was run at 65-70 mph and the tach was showing 1800-2000 rpm. Are all diesel trucks going to get this bad of mileage? I can understand the Yukons bad mpg because it its getting the tar worked out of it, but not the F-350.
Any ideas or input?
Thanks Steve
Any ideas or input?
Thanks Steve
