Re: Why not put a Petronix conversion on a 3.7 Mercruiser??
Make sure you follow the installation directions carefully. A mechanic installed my Pertronix Ignitor incorrectly. If you have a ballast resistor, or a resistance cable in the harness, the positive lead that feeds the Ignitor needs to tap in before the external resistor, not just be put on the coil positive post. When my harness resistance cable began deteriorating (increased resistance with heat), this caused huge problems--the voltage at the coil positive post would drop below 7.5V, and the Ignitor would shut down, killing the engine. The whole thing became difficult for me to troubleshoot, but I eventually got it straightened out. Other than the bad installation job by the mechanic, I've been very happy with the Ignitor. With the Ignitor II, I believe you don't have to worry about burning out the unit if the key is left in the "run" position with the engine not running.<br /><br />Steve
