gonefishie
- Jul 28, 2004
- 2,624
Are any of you guys using this type of converter from Draw-Tite and have any problem?<br /><br />
<br /><br />Well my problem is that the fuse that is in-line with the power wire connected directly to the battery keep blowing after about an hour of usage WITH THE RUNNING LIGHT ON. Without running light it works forever. I'm not new to trailer light problems and have checked all the ground and wires, bulb sockets, etc.. Do you think it could be that the converter is going bad and blowed the fuse when it gets hot? or have I not checked my running light wire throughly enough? If it's a problem with the running light circuit how come it took an hour for the fuse to blow instead of immediately?
