Why dose it put to to the right??
1983rinker
I have a 75 hp Chrysler that run's very good. My only prob. is when it going along at a good clip it want to pull right. And when I let go of the wheel it will go hard right. How can I stop this. Prop is very good shape. Can anyone give me some info??????
jerryjerry05
Re: Why dose it put to to the right??
Above the prop is a snout or fin.If the boat pulls to the right turn the fin to the right.Pulls left turn it left.J
1983rinker
I'll give it a try.
1983rinker
My skag is bent a little, will that make it turn as well? How can I bend it stright without braking it?
jerryjerry05
A slight bend can be done with a hammer.Slowly hit it till it goes back to shape.Post a pic.
A big bend might not be fixable unless it's heated.
Heating it can ruin seals and cook the oil.So take it to a prop shop,if it might be more than you want to mess with.Most of them can straighten skegs.J
milehighboater
If it is only alittle bent, triying to correct it with the "fin" and leaving the skeg bent wont hurt.
