skipjack27
- Oct 6, 2009
- 79
I have a major puzzle that I'd love someone to throw some light on. The puzzle was actually broached in an earlier thread on a crankcase breather problem, but I'm reluctant to pursue it further there. I received much invaluable advice in that thread and I'm reluctant to impose further on those very kind and knowledgeable respondents. By starting a new thread, they'll have the opportunity to pretend they haven't seen it!
Briefly: my Volvo AQAD41A (1450 hours; 23 years old; no previous rebuild as far as I know) is venting oil through the crankcase breather at a quite alarming rate. The problem only appears at revs above about 2700, and gets progressively worse as rpm increases until there is a continuous trickle of oil into the bilge in the 3100-3400rpm range. Mechanics ran a compression test and borescope, with the following results:
1: 16 (232)
2: 17 (247)
3: 19.5 (283)
4: 19.5 (283)
5: 16 (232)
6: 19 (276)
Above results were provided to me in bars, and I have converted to psi in brackets. Volvo says the service limit for this engine is 320psi. The borescope revealed "vertical scoring evident and cylinders polished (no cross-hatching)".
So, a pretty clear diagnosis of the breather problem, apparently: this is a very tired engine that is in dire need of a rebuild. Except...
- starts instantly in even the most freezing conditions (not literally freezing here in Perth, W.A., but still extremely cold in midwinter). Don't even have to use glow plugs. Just advance the throttle a little above idle, and she instantly bursts into life every time. In 18 months, I have NEVER experienced the slightest difficulty in starting her up. Combing other fora for a clue to what is going on, I noted the following reply to someone having similar problems: "how confident are you regarding the compression test? an easy start for a low compression diesel engine is an oxymoron. a worn-out engine will generally let you know by smoke and hard to start."
- blows NO smoke at all of any colour (white smoke on startup, which disappears after a few minutes - this is a known problem with this model, that was corrected on later models). I've hung over the transom at WOT and am utterly unable to detect any smoke at all.
- as far as I can determine, the engine is using essentially no detectable quantities of oil. This has been a little confounded by the breather problem, but when that has been avoided there is no evidence at all that she is burning oil (which is, of course, entirely consistent with the complete absence of any black smoke)
- runs extremely reliably: never conks under any circumstance, and appears to have all the acceleration and speed I could hope for in a boat of this sort. With a clean bottom, she reaches her rated 21 knot max speed at WOT.
What is going on here?? Mechanics have remarked to me that this model was possibly "the best marine diesel Volvo ever made", but it can't be that good. According to the compression test, this is an engine that is dead on its feet: very low compression in some cylinders, and substantial variation across cylinders. And yet, if it were not for the breather problem, I would never have suspected that the engine was not in prime condition.
I'm a relative diesel newbie, but I've owned gas engines for quite a long time - and I know all about tired gas engines. Impossible to start in cold weather (and not that easy in warm weather), conk every time they are put into gear, burn almost as much oil as fuel, poor out the kind of exhaust that originally gave rise to the "stinkboat" sobriquet, etc, etc.
So, can anyone educate me about diesels? How can such a tired engine behave so impeccably (with the sole exception of the breather problem)? Is this what diesels do? Could the compression test be seriously awry (the firm I deal with tends to put its youngest and/or least competent mechanics onto relatively small boats like mine)? But if it was inaccurate, why do I have such a bad breather problem?
Any perspectives on this apparent paradox would be greatly appreciated.
Jeff
1: 16 (232)
2: 17 (247)
3: 19.5 (283)
4: 19.5 (283)
5: 16 (232)
6: 19 (276)
Jeff
