Re: why does grease leake out of my bearing buddy?
yes i will take pics this afternoon. ive never serviced an axle so i dont know how to take a hub off, to get to the bearings. but i can do it with the right direction. i really appreciate it, and will have pics tonight. im goin on a 4 hour trip end of july and though i haven had any issues, i know something is not right with my axles so want to get it serviced.
It is a simple job to clean and even to repack them, the only worry you should have is when it comes to how much to tighten the axel nut which is a very important point. Very Very important.
Being this is a used trailer and you do not know when they were serviced or if the bearing buddies were just put on and then pumped full of grease.
You also do not know what to look for in what a good bearing is and what is not. There are good quality built bearings and yes even poor quality built bearings and again you do not know which is which.
Do not waist your time playing with what you have at the present time.
Complete quality built kits are about $25.00 a side which comes with all you need some kits even include gloves to keep your hand clean.
Just take one of your hubs off and get the bearing number on it and that's all you need.
Personally take the bearing buddies off and throw them away, put OEM caps on them and check them before any trip. Just as you check the tire pressure before you leave town, remember you are submerging the axel and leaving it sit underwater while you off loading or loading the boat.
If you are not comfortable with checking bearings for contamination switch over to a oil system where all you have to do is look into the site glass to tell if water got in.
There is a great deal of satisfaction of doing a job youself but being this would be your first try and intending on going on a 4 hour trip. That is a long time to be driving and wondering if you did everything correct which you probably did but that does not mean you wouldn't be thinking did I.
For that reason take it too a reputable shop and have them do it. It should be no more than a hour shop time (75.00 hour) and 25 bucks a side. Best $125.00 you will spend.
