What happen if i make it lighter?
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Apr 21, 2011 #2 Re: Why does a 4.3 engine flywheel it so heavy? They are supposed to be heavy.
vfrkent Seaman Joined Aug 18, 2010 Messages 62 May 12, 2011 #3 Re: Why does a 4.3 engine flywheel it so heavy? It helps dampen harmonic vibrations before they get to the drive unit, decreasing the weight increases wear on the drive unit. Regards, Kent
