who lives near toronto and can help me fix thiS @$$^# MOTOR
miloman
who lives near me that can help me fix this motor Id rather deal with one of you guys then a marin***
miloman
Re: who lives near toronto and can help me fix thiS @$$^# MOTOR
hey is there any one here able to help miloman@sympatico.c***
Trent
Make, model and year. And what's the problem?
miloman
HI THERE PULLED THE PLUGS SPRAYED CYLINDER WITH FOG FINGER TIGHTENED THE PLUGS, DIDNOT CONNECT THEM TURNED THE ENGINE OVER THE CABLES TO MY BATTERY GOT HOT AND NOW IT JUST MAKES A CLICKING SOUND THE BATTERY WAS CONNECTED PROPERLY WHAT DID I DO
Joe Reeves
Miloman.... It would have been better to continue on with the initial post rather than to have many posts scattered around that pertain to the same engine.
miloman
but what would be really great is someone near me who knows what the hell they are doing seems like all the great guys are in the states
miloman
i agree Joe what this post is about is there someone who lives near me who knows what they are doing
sony2001
Where your battery cables connect to the battery there is surface space lacking for the transfer of a lot of current. Buy some Marine Terminals in brass and use them on all subsequent batteries. Keep all surfaces clean of oxidation as well but in your case their isn't enough transfer surface for the large load. :cool:
miloman
actually did that today still hear the click but motor does not turn over
radsrh
Did you try to put a volt meter on the battery and see what it reads. It could be you just cranked it to long got the leads warm and now there is not enough juice in the battery to turn the motor over.
rickdb1boat
Starter is shot!!!!
miloman
thats what i was thinking whatshould that run me on my50 evinrude 1973 part alone I have to have my driveshaft seal done so looks like its seals while Im at it water pump or impeller and the starter what should I be willing to pay a marina to do this job if i dont tackle it myself
rickdb1boat
I would do the Starter myself. Very easy and will save you some dollars.Look below for prices. There are other places to get them, too. The one for yours is about $215.00. If you have a shop around that rebuilds car starters, they could do it for around $50.00.<br /><br /> Starters
rickdb1boat
Oh yeah, if a shop does it, I would guess at least $500.00 for everything. some of the Mechanics on here could probably get closer on the price.
plywoody
Miloman,<br /><br />Probably not much help, but I know a good guy in Blind River, Ontario that runs an outboard shop and does good work. He is no doubt very busy now getting snomobiles ready to go, and it is six hours north and west of you, but I thought I would throw it out there.<br /><br />Part of the advantage of doing the work yourself is that you can take the time to be methodical and careful and do it right. The key to this is to take a deep breath, and tackle one problem at a time. A starter is not a big deal, for example, nor is a seal. Taken one at a time, these problems are manageable with the help available here and a good shop manual.<br /><br />John
