White Smoke from Force 125
jonmon
Is it normal for white smoke to be coming out of my 1986 Force 125; it seems pretty heavy and can smell while in idle?
dtherrien
Re: White Smoke from Force 125
You should give more info..like...did you just buy the boat?....did the problem just start?<br />Check your spark plugs to see if they are "steamed cleaned"<br />I had a 86 125 and i would say the smoke looks white...even moreso with the temps cooling off alittle to.
TELMANMN
White usually means water but as dtherrien ask's?<br /> Also I have noticed that BP stations have an added whtever that stinks and does smoke white! It also stinks. It is just where I am?
timmathis
Does it get worse with RPM increace?
