JASinIL2006
- Feb 10, 2012
- 5,749
Hi all, I could use some diagnostic help with my engine.
My boat has a 350 Mag Alpha One Gen 2 (serial #s in my sig below). Boat is freshwater cooled. I ran it on muffs this morning to get it warmed up and everything seemed to be OK. (Except for a dead battery due to my daughter leaving the stereo on....) Took the family out last weekend (first real outing of the year) and the boat worked flawlessly.
Today, when warming up the engine at the dock after launching, I thought I saw a whiff of white smoke in the engine compartment. The wind was blowing right over the stern, though, and I thought it was maybe exhaust getting blown back into the boat. We idled down a small channel, got up on plane and made it to the main channel of the river. We then idled for about 5 minutes. Just to check, we opened the engine compartment and saw considerably more white smoke, smelled burning rubber and decided to head back in. During this time, the temp gauge was right where it normally is, about 160, and none of the other gauges showed anything unusual.
When we were back at the dock a few minutes later, there was still a bit of smoke and the smell of burned rubber, but not as bad as when we were out on the river. I could not see where the smoke might be coming from. I did feel the water hoses on the engine; the large lower hose on the starboard side of the engine was very warm. Not too hot to touch, but very warm. Exhaust manifolds were a little warm, but not much.
The belts looked OK; all the pulleys were turning, without any squeaking or squealing, and when I checked later, all are tight.
My first suspicion was the impeller/water pump in the outdrive, but I just pulled the drive, cracked it and removed the pump. The impeller and everything in the drive look fine. (I replaced the entire pump assembly about two years ago.)
Any idea of what I should check next? I'm a bit apprehensive about going back out on the water until I'm sure I've figured this out.
Thanks!
Jim
Thanks!
Jim
