Thanks i will give that a try.I think you have an electramatic shift lower unit, it uses coils and springs to shift the lower unit. Remove the two shift wires (blue and green) going to the lower unit, use a jumper wire and try and shift gears and see if forward works. If it does you probably have a shift switch or a wiring problem. If it doesn't shift with a jumper wire the problem is in the lower unit or wires going down to the lower unit.
