Which thrust washer. 1978 Johnson 150
tranquility
I bought a Michigan Stainless 15x17 prop. Model 389925. The original thrust washer allows the prop to slide down to far. Which thrust washer do I need to make this prop work and where can I order one. The engine is a 1978 Johnson 150.
Thanks.
Re: Which thrust washer. 1978 Johnson 150
Ayuh,... Call Michigan Wheel,... You need the washer that matches the Prop..
