Which spark plugs to use?
Texastoon
BR8HS-10 OR B8HS-10
They are both offered for my motor. I know one R is for resistance. What does that do.
Bob_VT
Re: Which spark plugs to use?
Well are you listening to a am/fm radio as you drive? It would probably cut back on the static.
Silvertip
If you have an EFI or DFI engine or a lot of sophisticated electronics on board you should run resistor plugs. This cuts down ignition related interference that can can cause static, but can also interfer with operation of the electronics.
