Re: Which prop
The iBoats forum has a pretty nice "search" function. I used the terms "Which Prop", "What prop" and "prop selection" as search terms and all three produced 217, 218, and 219 responses most of which would have answered your question. As QC pointed out, and the stickies at the top of the forum indicate, you cannot just slap on a different prop and magically make a boat an economy champ -- because no matter what you do, they suck suck fuel. The best prop is the one that allows the engine to run at or very near the upper end of the engine manufacturers recommended rpm band at wide open throttle with what you consider an average load. Yes -- we understand you don't run wide open all the time. But if the prop is wrong at WOT it is wrong at all other throttle settings as well. You need to determine what your current WOT rpm and speed is with the load you carry most often. "About" xx mph at "about" xxxx rpm with a xx/yyP prop is not an answer that can result in reasonable recommendations.
