Which model VP leg? Need to remove props
winbasic
Hi,
Looks like the weekend run has resulted in me picking up a crab pot as when the boat was lifted, the leg has a swag of crab pot rope wrapped around the base of the leg and between the Duo Props. When I got home, I checked the manual about how to remove the props only to be confronted with various models of legs.
Now the picture in the book tells me that I have a DP-E drive unit because of the 4 fin props but I don't have a cone. The DPX-DP-S and XDP props look closer to what I have but they are only 3 fin so now I'm confused!
Apart from what leg do I have, should I actually have a prop cone on my leg? Also, when I do actually remove the propellors to get rid of the remaining rope, do I need to grease the splines and do I need a new nut? Should they be torqued?
Thanks in advance for any assistance!!
Don S
Re: Which model VP leg? Need to remove props
It's a DP-S drive
winbasic
It's a DP-S drive
Thanks Don. Reading through the workshop manual it seems pretty straight forward. I'm assuming the propellor tool kit (Part # 3855516-5) must be a special tool and not a standard socket or torque wrench.
When I go to refit the front propellor, I understand it has splines which need to be lined up but how do I know what 'angle' to put it on in relation to the rear propellor or will it only go on in one particular position?
Don S
Moving to prop topics and questions.
The props are not timed, Just stick em on.
The outer prop takes a 1-3/16" socket. The inside prop needs the special wrench.
winbasic
Thanks again Don - should the leg have a 'prop cone' on it? The picture is how I purchased the boat but wasn't sure if I should have a cone or not.
