Which Maxum model is this?
Scarebird
Last week I picked up a 1994 Maxum bowrider with 4.3/Merc. I was told it was a 20 footer, but the title says 19. Hmm. Maxum seems to have a bewildering array of models (I thought they were a spinoff from Bayliner)
Title says:
Series/Body: PDGPR19
HIN: USJB60MUE494
need this info so I can get a few missing items, ie. covers, Bimini...
tashasdaddy
Re: Which Maxum model is this?
Bimini's are generic. you will have to hunt ebay, craigslist for the others. contact Maxum, with numbers maybe they can help.
Scarebird
Come Monday I guess that is what will happen. The tops advertised on this site - good?
Action
If you can find someone that makes boat tops, that is the best way I feel. Made to fit perfectly. The person I use for my tops uses the same sunbrella material that the manufacturer use so you get a great top that won't shrink. It is also much cheaper then ordering direct from the manufacturer if you are even able to still.
Scarebird
Upholsterers are the biggest flakes I deal with in the automotive world; at least painters have an excuse via chemicals...
Boat is sitting in the shop and was cleaning the workbench while gawking at said boat - figuring on how to remove 5" high plastic "MAXUM" lettering from side - then wondered if I should remove "2000 SR" lettering also.
*hits forehead with fist*
