You can use a Mercury Flo-torque II, Solas Rubex hub, Turning Point hub, or a Michigan Wheel hub. They are all interchangeable. I just bought a Turning point prop and Solas hub. Because the TP is a composite that means if you hit something it will destroy the hub and leave a plastic shreds, and you will have to paddle back. Whereas a rubber hub will have more give, and if hits something will slip and kind of reset, so you will be able to limp back with it.
