Which belt do I need?
Don S
Re: Which belt do I need?
In your link, you would need the 006 belt, unless you have the Compact Hydraulic Steering system on your boat. If you do have CHS, you would use the 008 belt.
I have no idea if CHS was even available on your model or not. They don't show it in the parts breakdown, just list it in the options.
jg5343
Thank you. Just out of curiosity, how did you know that?
Bt Doctur
Lets see, Wizard holding a crystal ball with over 35,000 posts.
Don S knows everything EXCEPT Powerball numbers.
Don S
I know the Powerball numbers, I'm just not allowed to play ;) :p :p
Seriously, I have access to the OEM Dealer information.
In the parts lookup, there is a comments section that explains what each is for.
Look at all the belts listed for item #28.
attachment.php
