Re: Which battery and circuit set-up?
Lead acid batteries give you the best bang for your buck as far as capacity goes (Ah). There are three forms:<br />Flooded Cell - Cheapest power. Downsides are they need maintanance (occasional water added), must be kept upright, and leak acid if punctured. They can supply lots of current quickly if needed.<br />Gel cell - Medium cost. Downsides are they leak gel if broken, and cannot deliver a lot of power quickly. Advantages are no maintanance, can be operated in any orientation.<br />AGM - Highest cost new kid on the block. Downside is price. Upside is they don't leak if broken, can be operated in any position, can deliver very large amounts of power quickly (better than flooded deep cycles), no maintanace, and can last longer and survive deep discharges better than any other. Self-discharge rate is also low.<br /><br />NiCd is very expensive compared to any form of lead acid, but is very light for the amount of power it can deliver. It's got all the advantages of AGM, except it self-discharges fairly rapidly. You can expect a life of around 600 cycles.<br /><br />I think AGM is really the ideal battery for what you're doing, and flooded is an option if price is the issue. I really don't see gel as being a very useful battery anymore. It's really old technology.
