Which anode type to use? Mg Al Zn
PitchFork
I have a Alpha One Gen 1 with SS Prop trailered only used in freshwater 120 hours a season.
I recently purchased an aluminium anode kit and wanted to make sure this is ok to use or should I look for an Magnesium Kit?
Kit has Trim Tab, trim ram rod, Gimbal Housing, and transom bolt anodes.
I'm not sure what anode type is on it now it has been on their since I bought the boat 3 years ago.
Thanks,
PF
Bifflefan
Re: Which anode type to use? Mg Al Zn
After reading this link, I guess I dont know anything about them. But I do know a bit more now.
PitchFork
Thanks I guess Aluminium is the winner I will be installing ithe kit with my new SE106 drive tomorrow.
Bluestream
Since the gear case in Aluminium, whats the point of an aluminium anode? I would use the zinc as they came with the drive when new...
Dshow
When would magnesium be used? I've heard magnesium is used for freshwater, why not that?
According to the Merc site:
All MerCruiser sterndrives come standard with aluminum sacrificial anodes & 3-year warranty against certain types of corrosion (see your owner's manual for more details). Seacore models receive a four-year limited corrosion warranty.
http://www.mercurymarine.com/servic...intenance/faqs/mercruiser/?category=corrosion
Bifflefan
Read the link I posted.
Yes it is. Also read the link.
sethjon
Thanks,
PF
If you stay fresh water use mag. Zinc is good for either.
Don S
Completely different types of aluminum alloy. Merc stopped using zinc many years ago, because it didn't work very well. Here is one of the service bulletins from 91 on the change from zinc to aluminum anodes.
http://www.boatfix.com/merc/Bullet/91/91_19.pdf
Magnesium anodes are for freshwater only, not to be used in saltwater, aluminum can be used in either fresh or salt.
For a trailered boat magnesium or aluminum will work because the boat is not sitting at a dock where the anodes are needed most.
sethjon
But magnesium is better in fresh water which is not good for salt.
SteveRay
Check out boatzincs.com.......Awesome people and great service.
I can tell you that I learned the hard way this year....I have an Alpha Gen II
with stainless prop and left original anodes in great shape on and suffered corrosion as a result of the stainless prop.
Bluestream
I wonder why it took 20 years to figure this out?
On my 22 year old boat the zinc seems to have worked very well. No corrosion on the aluminium, and the 3 zinc anodes are about 50% gone.
