wheres the water come out
DSL DOC
hi guys and gals ne1 know where the water is supposed to exit the engine 1962 evinrude 40 hp model 35530L serial 05923 and by those numbers is it really a 40 hp there a 3 holes upper leg 1 about an inch or so in diamter and 2 small say 3/8" holes under that and another hole real close to the prop after running motor looks like exhaust is there down by prop but what about the water trying to see if need water pump and therm immed or could use light use just to get on water i suppose i could run it in can and see if it gets real warm or not i do have an infrared temp gun could use what would head temp be or best place to check temp
Walker
Re: wheres the water come out
Be safe and change the impellor before you try to use the motor. Cheap preventative maintenance.
OBJ
Hi ya' doin Doc?<br /><br />Yep, ya' got a 1962 40hp Rude there.<br /><br />If memory serves, look inback of the prop and you will see a tab hanging down from the anti-cav plate with a hole in it. The return water exits there. Also, some will spit out the hole that is located at the rear of the midsection just below the lower engine pan.<br /><br />At idle, the engine temp should read approx. 140 to 145 degrees F. when measured at the flat spot just behind the head on top of the engine. The thermostat is located there also underneath a three bolt cover. The cover will be triangular in shape. <br /><br />Make sure the lower unit is in the water well above the lower unit to midsection matting line if you run it on dry land. A garbage can will suffice ok if ya' don't rev her up. Just keep her at idle.<br /><br />Hope we've helped.
