Re: Where's the oil sending port on F115 Yamaha 4-Stroke?
Fellas,
Bypass filtration "bypasses" approximately 10 percent of the sumps capacity while the engine is running. The full flow filter is still retained. The bypass filter mount has a restrictor orifice that is 1/16th of 1 inch (that's tiny). That allows the bypass filter (bypass filters are setup different than full flows) to "super clean" the oil. Remember, oil doesn't wear out it just gets dirty from blow-by, contamination, etc...from the engine.
A bypass filter removes abrasive particles from your crankcase oil, keeps insolubles to nearly zero, and allows the oils chemistry to not deplete itself therefore oil changes are darn near a thing of the past.
I have a Powerstroke diesel and have a bypass setup on it and with 7000 miles on my oil under a 100x microscope that lab technician stated that my oil "looked as clean or cleaner than new oil out of the bottle". By the way, to be able to tell how far you can go on your OCI's (oil change intervals) routine oil analysis' is always recommended.
To learn about bypass filtration and oil in general check out
Bob is the Oil Guy.
