convergent
- May 17, 2010
- 385
I was out on the lake this weekend and took on a bit of water over the bow a couple of times and surprisingly never had anything coming out the bilge pump outlet. I have a manual switch override that I flipped and nothing. When I pulled the plug after I took the boat out of the water a lot of water came out... would assume that it should have been able to eject some with the pump. I know the pump worked at some point since I bought the boat and was thinking maybe it blew a fuse or something. Where would fuses or circuit breakers usually be located? This is a fish and ski hull that seems to be built similarly to most of the ones I've seen.
What made me think of this was that as we were leaving the lake yesterday a group of older guys were launching a center console. They didn't really look like they had done it a lot from the dialog that I heard and watching them work. After they got the boat off the trailer I noticed that their bilge outlet was spraying a steady stream of water like a garden hose. It never stopped. I was putting on my stern straps and cleaning up the boat to leave and couldn't stop watching. As the guy was pulling the trailer out to park it, I asked him if he knew if they put the plug in the boat because a lot of water was coming out from the bilge pump, and he said... "that's a good question, I need to check". Another several minutes went by and the guy driving the boat was sort of circling around at the end of the dock, I presume trying to get it back to the dock so they could board. We finally left and the boat still had a steady flow of water out the bilge outlet. Hopefully they didn't sink.
