where to plumb in water heater on mercruiser 5.7
findinghomer
engine is 1997 mercruiser v8 5.7. 350 ci, alpha one drive. i have atwood water heater that i would like to plumb into this cooling system. just want to be sure i do it correct. anyone got this same setup could give me pointers? thanks in advance.
Re: where to plumb in water heater on mercruiser 5.7
Ayuh,... The Hottest water, at the greatest pressure is in the intake manifold, behind the T-stat...
You should have a 1/2" pipe plug in the cooling passage of yer intake...
The lowest pressure point available is into the 1/2" pipe plug in yer circulating water pump...
That's yer return point to insure Flow...
Don S
Here is how it shows to do it in the manual.
  • Adding HWH.pdf
