cbass74429
- May 11, 2006
- 120
I have a 2000 19SS extreme,that has a through hull transducer. Quits working, no signal return, when I run 55MPH and higher. I know this is air under the boat. I purchased a new GPS/Fish Finder,and it has a skimmer transducer. I just would like to find out excatly where I should place it? My boat is stepped from keel to transom area. Have drain and inlets for live well at bottom near keel. This is a common thing on most newer boats. I don't want to put in inside because it has a temp sensor built in. So I would appericate any help!
Thank You David Crockett Sr.
