I've got a 2000 tracker pro deep v17. I'm upgrading the depthfinder and trying to find the best location to mount it the transducer. I've included a picture to make things clearer. I can't mount it where the existing transducer is b/c the existing one currently hits the bunk on the new trailer. I would mount it just to the right, but there is a strake/rib there and I'm worried about turbulance. So I can mount it a little further to the right, but then I'm only 8-9" away from the corner, will that be a problem? The other option is going towards the center, but I'm a little worried about getting to close to the lower unit, Lowrance says you should avoid being closer than 12" from the lower unit due to turbulance, and to the left of the bunk with enough clearance would be about 11". So what do you guys think? My first boat, my first project with it. have a friend who will help thats done it before, just don't want to be drilling more holes than necessary. Should I consider one of those plastic plates to mount it to?
Thanks in advance.
Thanks in advance.
